Hello, I am having a problem with the current operating system for Leapfrog 48 (Zeros 7.9.5) (At this time running 7.9.4). It seems to me that something is going wrong with the installation.
In the operation of the desk I noticed different things that are not correct. For example, the "new" effect generator does not exist at all ... When I press "Create auto pallets" nothing happens.
The console is absolutely useless for me without effects ...
Have the OS now installed for 3x (at the Usb port between Ethernet and monitor port) and nothing has changed.
Please Help ...
Hi Louks,
It sounds like you are trying to install the console software using the old installation method. For instructions on installing ZerOS 7.9.5 from 7.9.4, see the article below...
http://support.zero88.com/1518910761
Hope this helps, if you have any questions let us know.
1 minute ago, Edward- Z88 said:
Hi Louks,
It sounds like you are trying to install the console software using the old installation method. For instructions on installing ZerOS 7.9.5 from 7.9.4, see the instructions below...
I will Try it ! :D
