van den abbeele Eric Posted September 9, 2019 Report Share Posted September 9, 2019 Hello, After reading this, I have question or rather need a clarification on the option "fader control" If I understood correctly this option allows to have a specific control on an element (color, position, etc ...) Concretely, how is it? I have on one side MMF Fader in channel mode that control the different projectors (Leds, traditional and moving head) on the other side I have my master fader that records and reads the cues. How do I proceed? I imagine on MMF 24 in channel mode a moving head (with all the parameters accessible with color, beam, effect, move ...) How to activate control fader for example on just the pan? Thanks for your help ? eric Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 3 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 5 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 5 PARWASH 19 X 15w // 10 Spot 200w // 19 Wash Par 12 X 18W // 2 BOWLDER 12X40w WASH // 11 PARZOOM 19 X 15w Link to comment Share on other sites More sharing options...
Edward Z88 Posted September 10, 2019 Report Share Posted September 10, 2019 Hi Eric, The Fader Controls option allows parameters of the enabled attributes, to be scaled manually from their current value, to their programmed value, rather than snapping or fading as soon as the playback is triggered. If you have a playback where you would like to enable Fader Controls position, go into the playback settings, and choose position. Now this fader will control the intensity, but also the position of the recorded fixtures. Hope this helps, Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
van den abbeele Eric Posted September 10, 2019 Author Report Share Posted September 10, 2019 Hello, I'm not sure I understood the way to do that. I'm going this weekend, take the FLX (which I just received) and see a little how to do this concretely. In fact having the FLX + 2 wings, in general I use the 72 MFF faders in chanel mode. To have access to all my projectors. But if I understand a little things, to use a "fader control," I have to be in the playback mode on the side of my MFF fader. That is, at least one wing? Is this? merci pour votre aide Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 3 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 5 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 5 PARWASH 19 X 15w // 10 Spot 200w // 19 Wash Par 12 X 18W // 2 BOWLDER 12X40w WASH // 11 PARZOOM 19 X 15w Link to comment Share on other sites More sharing options...
Edward Z88 Posted September 10, 2019 Report Share Posted September 10, 2019 Hello, 1 hour ago, van den abbeele Eric said: But if I understand a little things, to use a "fader control," I have to be in the playback mode on the side of my MFF fader. That's correct - Fader Controls, can be enabled per attribute of a playback. In channels function, the faders will only ever control a channel's intensity. All the best, Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
van den abbeele Eric Posted September 10, 2019 Author Report Share Posted September 10, 2019 OK thank ! I will try it soon. Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 3 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 5 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 5 PARWASH 19 X 15w // 10 Spot 200w // 19 Wash Par 12 X 18W // 2 BOWLDER 12X40w WASH // 11 PARZOOM 19 X 15w Link to comment Share on other sites More sharing options...
