After reading this, I have question or rather need a clarification on the option "fader control"
If I understood correctly this option allows to have a specific control on an element (color, position, etc ...)
Concretely, how is it?
I have on one side MMF Fader in channel mode that control the different projectors (Leds, traditional and moving head)
on the other side I have my master fader that records and reads the cues.
How do I proceed?
I imagine on MMF 24 in channel mode a moving head (with all the parameters accessible with color, beam, effect, move ...)
How to activate control fader for example on just the pan?
Thanks for your help ?
eric
Hi Eric,
The Fader Controls option allows parameters of the enabled attributes, to be scaled manually from their current value, to their programmed value, rather than snapping or fading as soon as the playback is triggered.
If you have a playback where you would like to enable Fader Controls position, go into the playback settings, and choose position. Now this fader will control the intensity, but also the position of the recorded fixtures.
Hope this helps,
I'm not sure I understood the way to do that.
I'm going this weekend, take the FLX (which I just received) and see a little how to do this concretely.
In fact having the FLX + 2 wings, in general I use the 72 MFF faders in chanel mode. To have access to all my projectors.
But if I understand a little things, to use a "fader control," I have to be in the playback mode on the side of my MFF fader. That is, at least one wing? Is this?
merci pour votre aide
Expand
That's correct - Fader Controls, can be enabled per attribute of a playback. In channels function, the faders will only ever control a channel's intensity.
All the best,
OK thank !
I will try it soon.
