Effects / use and control effects
RogerA
Hi,
I work with Solution console and  I would like to programming changes, something to do advanced light handling and not just turn-on /off.
After read again et again I don't undertand if understand if is possible to apply effects in playbacks, memmories  or submaster with any ligths or just with some of them. I work with  Cameo Flat Pro 18 (LED), Ignition Strip Blinder X  ( hallogens) and classic ligths ( Juillat, ADB,etc) . Before  having added my fixtures and created palettes , I can't apply effects. (Only one option is possible and does not work).
I ve sear
Hi Roger,
If you are running the latest release software, when you press "Automatically Create Effect Palettes" 45 auto effects should be created. ZerOS 7.9.5 is the latest release software for Solution. If only one effect palette is created, please try installing ZerOS 7.9.5 again.
ZerOS 7.9.5 can be downloaded from our website here...
Installation instructions can be found here...
http://support.zero88.com/1518910761
Hope this helps, if you have any questions let us know.
Hi Edward,
yes  installed it again and it works. THANKS. I have spent many hours circling without finding a response.
I have some  MKF with red led on and others redl Led off. I think that depend what kind of fixture I having selected
Now, I'ill try to creat my effects : turn-on, one by one , any lamp on my strip blinder ( with 10 lamps) to manage differents options.
any suggest ?
Thnaks again
Hi Roger,
Is the strip blinder patched as a single fixture on your Solution or as 10 individual dimmers? If patched as 10 individual dimmer channels, you can use the automatic Chaser effects, and apply an offset. If you have a single fixture patched with each Lamp under the "Beamshape" attribute, you will need to go to the Waveforms tab of the Effects window, and apply a Sine wave, speed, size and offset for each lamp. To open the Effects window, hold SHIFT and tap EFFECT.
Hi Edwards,
many questions.
1)
On 9/6/2019 at 3:22 PM, Edward- Z88 said:
Hi Roger,
I tried that and it did not work.
2)
I tried that also and it did not work.
3)
At last....not MACROS  in console after update
Edited by Edward- Z88
Font size reduced
Hi Edward,
I received your e-mail and I managed to program an effect with an offset. I appreciate your help. But I can not apply the effects on the 10 individual dimmers for the Stripblinder.
another question:
when I select my fixture Stripblinder and the press Home the lamps ar not on. And I have to select one by one and move weel to turn on all individual dimmer. It is possible to add modifictaion to mode HOME in this kind of fixture to turn on all dimmer one touch or one weel ?
I try to edditing effetcs and I follow the instructions by the manual but is not possible.
Thanks.
Roger
Hi Roger,
Auto effects cannot be used across individual lamps of a single fixture, hence you need to build the effect using Waveforms.
If the strip blinder was patched as 10 individual dimmers, you would be able to use auto effects.
Yes, fixture Home values can be edited. For information on editing fixture Home values, take a look at the article below...
http://support.zero88.com/1011411491
Hope this helps,
Yes, I understand and it's work well like you told me at the mail. 👍
I try this option also, but effects are not enables for individual dimmers.
not possible to edit effects
thanks
Roger
Hi Roger,
Of the 45 auto effects, effects 2 through to 10 are intensity effects. Do you find these are greyed out, and therefore cannot be applied?
Auto Effects cannot be edited, as they are used to create custom effect palettes. To edit custom effect palettes, apply the effect to your fixtures, make changes using the encoder wheels, tap UPDATE, and then press the effect palette to store the edits.
Hope this helps,
yes, they are not enble. only they are "On" ( red ) with fixtures are selected.
I try that,  I move up just Speed , UPDATE and now my Effect plalette ( created one by one with Sine wave)  doesn't work
Thanks
Roger
Hi Edward,
I tried again from the beginning  "programmation effects + edit " and now it works.  👍
Are feffects enabled only with fixtures and not with presets ?
Thanks again
Roger
Hi Roger,
That's great, glad to hear it.
Effects can be applied to selected fixtures. To store all parameters into a palette, hold SHIFT and tap RECORD, before choosing an empty effect palette.
Hope this helps,
