RogerA Posted September 6, 2019 Report Share Posted September 6, 2019 Hi, I work with Solution console and I would like to programming changes, something to do advanced light handling and not just turn-on /off. After read again et again I don't undertand if understand if is possible to apply effects in playbacks, memmories or submaster with any ligths or just with some of them. I work with Cameo Flat Pro 18 (LED), Ignition Strip Blinder X ( hallogens) and classic ligths ( Juillat, ADB,etc) . Before having added my fixtures and created palettes , I can't apply effects. (Only one option is possible and does not work). I ve sear Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted September 6, 2019 Report Share Posted September 6, 2019 Hi Roger, If you are running the latest release software, when you press "Automatically Create Effect Palettes" 45 auto effects should be created. ZerOS 7.9.5 is the latest release software for Solution. If only one effect palette is created, please try installing ZerOS 7.9.5 again. ZerOS 7.9.5 can be downloaded from our website here... Installation instructions can be found here... http://support.zero88.com/1518910761 Hope this helps, if you have any questions let us know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
RogerA Posted September 6, 2019 Author Report Share Posted September 6, 2019 Hi Edward, yes installed it again and it works. THANKS. I have spent many hours circling without finding a response. I have some MKF with red led on and others redl Led off. I think that depend what kind of fixture I having selected Now, I'ill try to creat my effects : turn-on, one by one , any lamp on my strip blinder ( with 10 lamps) to manage differents options. any suggest ? Thnaks again Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted September 6, 2019 Report Share Posted September 6, 2019 Hi Roger, Is the strip blinder patched as a single fixture on your Solution or as 10 individual dimmers? If patched as 10 individual dimmer channels, you can use the automatic Chaser effects, and apply an offset. If you have a single fixture patched with each Lamp under the "Beamshape" attribute, you will need to go to the Waveforms tab of the Effects window, and apply a Sine wave, speed, size and offset for each lamp. To open the Effects window, hold SHIFT and tap EFFECT. Hope this helps, if you have any questions let us know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
RogerA Posted September 13, 2019 Author Report Share Posted September 13, 2019 (edited) Hi Edwards, many questions. 1) On 9/6/2019 at 3:22 PM, Edward- Z88 said: Hi Roger, Is the strip blinder patched as a single fixture on your Solution or as 10 individual dimmers? If patched as 10 individual dimmer channels, you can use the automatic Chaser effects, and apply an offset. I tried that and it did not work. 2) On 9/6/2019 at 3:22 PM, Edward- Z88 said: If you have a single fixture patched with each Lamp under the "Beamshape" attribute, you will need to go to the Waveforms tab of the Effects window, and apply a Sine wave, speed, size and offset for each lamp. To open the Effects window, hold SHIFT and tap EFFECT. I tried that also and it did not work. 3) At last....not MACROS in console after update Edited September 13, 2019 by Edward- Z88 Font size reduced Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted September 13, 2019 Report Share Posted September 13, 2019 Hi Roger, Please send a copy of your show file to support@zero88.com, and one of the team will be able to take a look to see why the effects are not working for your strip blinders. If you have any questions let us know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
RogerA Posted September 17, 2019 Author Report Share Posted September 17, 2019 Hi Edward, I received your e-mail and I managed to program an effect with an offset. I appreciate your help. But I can not apply the effects on the 10 individual dimmers for the Stripblinder. another question: when I select my fixture Stripblinder and the press Home the lamps ar not on. And I have to select one by one and move weel to turn on all individual dimmer. It is possible to add modifictaion to mode HOME in this kind of fixture to turn on all dimmer one touch or one weel ? I try to edditing effetcs and I follow the instructions by the manual but is not possible. Thanks. Roger Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted September 18, 2019 Report Share Posted September 18, 2019 Hi Roger, Auto effects cannot be used across individual lamps of a single fixture, hence you need to build the effect using Waveforms. If the strip blinder was patched as 10 individual dimmers, you would be able to use auto effects. 23 hours ago, RogerA said: when I select my fixture Stripblinder and the press Home the lamps ar not on. And I have to select one by one and move weel to turn on all individual dimmer. It is possible to add modifictaion to mode HOME in this kind of fixture to turn on all dimmer one touch or one weel ? Yes, fixture Home values can be edited. For information on editing fixture Home values, take a look at the article below... http://support.zero88.com/1011411491 Hope this helps, Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
RogerA Posted September 18, 2019 Author Report Share Posted September 18, 2019 38 minutes ago, Edward- Z88 said: Auto effects cannot be used across individual lamps of a single fixture, hence you need to build the effect using Waveforms. Yes, I understand and it's work well like you told me at the mail. 👍 40 minutes ago, Edward- Z88 said: If the strip blinder was patched as 10 individual dimmers, you would be able to use auto effects. I try this option also, but effects are not enables for individual dimmers. On 9/17/2019 at 4:44 PM, RogerA said: I try to edditing effetcs and I follow the instructions by the manual but is not possible. not possible to edit effects thanks Roger Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted September 18, 2019 Report Share Posted September 18, 2019 Hi Roger, 2 minutes ago, RogerA said: I try this option also, but effects are not enables for individual dimmers. Of the 45 auto effects, effects 2 through to 10 are intensity effects. Do you find these are greyed out, and therefore cannot be applied? 3 minutes ago, RogerA said: not possible to edit effects Auto Effects cannot be edited, as they are used to create custom effect palettes. To edit custom effect palettes, apply the effect to your fixtures, make changes using the encoder wheels, tap UPDATE, and then press the effect palette to store the edits. Hope this helps, Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
RogerA Posted September 18, 2019 Author Report Share Posted September 18, 2019 16 minutes ago, Edward- Z88 said: Of the 45 auto effects, effects 2 through to 10 are intensity effects. Do you find these are greyed out, and therefore cannot be applied? yes, they are not enble. only they are "On" ( red ) with fixtures are selected. 20 minutes ago, Edward- Z88 said: Auto Effects cannot be edited, as they are used to create custom effect palettes. To edit custom effect palettes, apply the effect to your fixtures, make changes using the encoder wheels, tap UPDATE, and then press the effect palette to store the edits. I try that, I move up just Speed , UPDATE and now my Effect plalette ( created one by one with Sine wave) doesn't work Thanks Roger Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted September 19, 2019 Report Share Posted September 19, 2019 Hi Roger, Please could you send us the latest copy of your show file, and detail which fixtures aren't working with which effects? Please send this to support@zero88.com. If you have any questions let us know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
RogerA Posted September 19, 2019 Author Report Share Posted September 19, 2019 20 hours ago, Edward- Z88 said: Auto Effects cannot be edited, as they are used to create custom effect palettes. To edit custom effect palettes, apply the effect to your fixtures, make changes using the encoder wheels, tap UPDATE, and then press the effect palette to store the edits. Hi Edward, I tried again from the beginning "programmation effects + edit " and now it works. 👍 Are feffects enabled only with fixtures and not with presets ? Thanks again Roger Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted September 19, 2019 Report Share Posted September 19, 2019 Hi Roger, 2 hours ago, RogerA said: I tried again from the beginning "programmation effects + edit " and now it works. That's great, glad to hear it. 2 hours ago, RogerA said: Are feffects enabled only with fixtures and not with presets ? Effects can be applied to selected fixtures. To store all parameters into a palette, hold SHIFT and tap RECORD, before choosing an empty effect palette. Hope this helps, Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
