BryanBeattie Posted August 25, 2019 Report Posted August 25, 2019 I have patched an Equinox Fusion 120 from pick list and FLXS24 has assigned 16 channels to it. Have set Fusion 120 to 16ch mode. When I slide up the fader no lights come on but it seems to allow Color picking and pan, zoom and tilt work. I factory reset the Fusion 120 and first one starts on channel 1 on console and fixture and a red blinking dot shows DMX signal going to it/ them. Quote
Davidmk Posted August 25, 2019 Report Posted August 25, 2019 No expert on this fixture but have a look at what value ch7 is set to. A common trap (with non-LEDs) is that the shutter has to be set to something non-zero for any light to come out. Some LED fixtures seem to emulate this behaviour. You will also need one or more of the RGBW channels to be non-zero but I suspect you've thought of that. Quote
BryanBeattie Posted August 25, 2019 Author Report Posted August 25, 2019 Thanks for taking the time to reply. I checked RGBW channels were non zero. How do I see the value of the other channels eg 7? Quote
Edward Z88 Posted August 25, 2019 Report Posted August 25, 2019 Hello, See if there is a “Shutter” parameter or similar under the Beam attribute. What value is this set to? Most fixtures personalities should be configured so that when intensity is raised, you will achieve White light output. Therefore parameters such as RGBW or Shutter are preset at values specified in the fixture’s manual to allow this. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Davidmk Posted August 25, 2019 Report Posted August 25, 2019 It probably comes up as strobe under beam parameters. Try setting it to 255 or 100%. Refer to the fixture manual to see why. EQLED068_Manual.pdfFetching info... Quote
Davidmk Posted August 25, 2019 Report Posted August 25, 2019 (This is all assuming I have the right manual of course 🙂) Quote
BryanBeattie Posted August 25, 2019 Author Report Posted August 25, 2019 Thanks to everyone. Will have another play with it next week. Quote
Joe Gasser Posted September 5, 2019 Report Posted September 5, 2019 Try switching your faders from submasters to channels. There should be a button next to your faders. If not, try type in the channel number on the keypad and type an intensity. ex. 128@50 (enter) Quote
