phannington Posted August 19, 2019 Report Share Posted August 19, 2019 Hi, I am currently running 7.9.4 on an Orb desk and wish to upgrade to 7.9.5. Previously I have used the USB tool to prepare an upgrade but this time I should be able to upgrade using the load file in setup. I have extracted the 7.9.5 exe to a USB stick and I can see the file and select it within the load file screen. Initially I get the 2 confirmation screens that I am about to upgrade the OS which will delete all settings, but when I click on OK to both screens I am presented with a screen with the message 'File does not contain an upgrade package'. I didn't see a separate download for an upgrade install - have I missed something or is something else wrong ? Many thanks Paul Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted August 19, 2019 Report Share Posted August 19, 2019 Hi Paul, Just to double check, the software installation application to be loaded into the console is "ZerOS OS Creator USB - v7.9.5 17-5-2019 MD.exe". If you are running ZerOS 7.9.4 you will be able to tap SETUP -> Load File, and choose this file and load it in. Also available with the ZerOS 7.9.5 download is Phantom ZerOS 7.9.5. This is not the console software - this is the offline editor. If you try loading this into the console you will receive the error you described. Hope this helps and solves the issue. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
phannington Posted August 19, 2019 Author Report Share Posted August 19, 2019 I suspect that's it ... it's Monday morning. I steered away from the USB creator download as I assumed I didn't need that. I guess I wasn't expecting the Phantom link to be among the options. Thanks Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted August 19, 2019 Report Share Posted August 19, 2019 Hi Paul, No problem - let us know if there's anything else we can help with. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
