I'm using the FLX S24 mode of the Phantom ZerOS 7.9.5 and I've recorded a few cues into the master playback. I've somehow managed to get the first cue playing however when I press Go it doesn't move to the second cue automatically.
Have you changed the Master Playback's Fader Function? To find out hold SETUP and press the Master Playback's button. The default is HTP Master. If it is set to either of the Manual Fade options, the Go button is disabled. The fader's travel will then allow you to advance between cues instead of the button. If you want to use the Go button, change this back to HTP Master.
Hope this helps,
Email Support
22 minutes ago, Edward- Z88 said:
Hope this helps,
This is my current settings. I just tried setting the GM to 100% and now when I highlight cue 2 and press Go it would just jump back to cue 1.
Update: The Go button works but only if I set the GM to 0, press Go and set the GM back to 100.
Interesting, please could you send a copy of your show file to support@zero88.com with a link to this forum thread, and we'll take a look to see what may be causing this.
If you save your show file, and then load it back in again, does the issue persist?
Email Support
