drscoop Posted July 27, 2019 Report Posted July 27, 2019 Hi, On a current show we have a mix of effects (colour fades across the cyc, and a circle 8 on moving heads) running alongside a more conventional colour chase on some fresnels, all on the same cue fader. I know if I tap the relevant flash button the fresnels will change their timing to my tap, but is there a similarly easy way to change the effects engine timing in a live manner? Quote
kgallen Posted July 27, 2019 Report Posted July 27, 2019 Speed override. Shift+unprogrammed playback button then select Speed Override. Quote
Edward Z88 Posted July 27, 2019 Report Posted July 27, 2019 Hello, As Kevin says, Speed Override will do this for you. It will control the speed of the currently viewed playback - so first you'll need to press and hold VIEW and tap the playback button of your effect. You can then use the Speed Override encoder by pressing Z/Shift, or configure a Speed Override fader by pressing SETUP and tap an unprogrammed playback. All the best, Edward Quote Edward Smith Product Specialist Email Support
