stepan s Posted July 15, 2019 Report Posted July 15, 2019 Is there any possibilities to set effect speed using BPM? For example: ramp up in offset- light starts on quarter note in 96 bpm. thanks Quote
Edward Z88 Posted July 15, 2019 Report Posted July 15, 2019 Hi Stepan, Effect speed can't currently be controlled by BPM. Chases however can be assigned a BPM tempo. All the best, Edward Quote Edward Smith Product Specialist Email Support
stepan s Posted July 16, 2019 Author Report Posted July 16, 2019 Thanks, Now I try to find possibilities to control BPM. Can I use Midi beat clock from Ableton or protools? Or Only way is trigger cues by timecode and set bpm in playback. step Quote
Edward Z88 Posted July 16, 2019 Report Posted July 16, 2019 Hi Step, On FLX, cues can be triggered by the Go button, the previous cue, the real time clock, or MIDI. For more information on MIDI triggers, see below... http://support.zero88.com/990063141 BPM speeds can be configured for any chase, or a global BPM can be used. For more information on Global BPM, see the article below... http://support.zero88.com/1011580981 Hope this helps, Edward Quote Edward Smith Product Specialist Email Support
