ethan1997may Posted July 11, 2019 Report Posted July 11, 2019 This may be a stupid question but other than using macros to reset fixtures and lamp them on what other things can macros be used for? Quote
Edward Z88 Posted July 12, 2019 Report Posted July 12, 2019 Hi Ethan, When you press "Automatically Create Macros", these are Fixture Macros, which are generated from the currently patched fixtures. However, Macros can also be programmed, to save you button presses on the console. For example, you might program a macro that selects some fixtures, and takes you straight to the colour MFKs. This would be programmed by using the following command: RECORD -> MACRO -> choose an empty Macro MFK -> Choose to record either keys, or the command line -> select your fixtures -> COLOUR -> MACRO. The macro is now stored, and now when you press this macro palette, the fixtures will be selected and colour will display on the MFKs. Macros can then be triggered by cues, meaning you could simply record a macro of the Playbacks page button being pressed, and then have this triggered by a cue in the cue stack when you need to access the next playback page. If you have any queries let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
