So the director has called for a last minute blue-out, I raise a playback with dim blue LEDs and lower the main memory master (cue stack 0) - only to find that the cue stack has gone from cue XX, back to the beginning.
Can I change that behavior so it doesn't change the cue, just lowers the memory to 0%?
Can I select a cue to trigger - rather than having to tap 'go' X amount of times to get to where I was?
I'm using a Solution with 7.9.5 installed.
Thanks
Thanks for the fast response however I'm still stuck. SETUP+playback gives me an option screen on my monitor, but no release options.. I just have playback type (general, chase, raise/lower, etc), Intensity mixing, fader function, fader controls and button function.
None of the buttons lists a release function :(
