Jazwinski Posted July 10, 2019 Report Share Posted July 10, 2019 How do you connect an Enttec Wing to an FLXs24? Detailed instructions please! (Enttec wing in DHCP mode and Enttec Mode, FLX connected to same network, My Ipad controls FLX no problem, so networking good) Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted July 10, 2019 Report Share Posted July 10, 2019 Hello, ENTTEC Wings are no longer supported by ZerOS. You will therefore have to run an old software version on your FLX to be able to use them. What software version are you running on your FLX? You can find out by tapping Z -> System Information. If you are on an older version, you will be able to connect your wing, FLX, and other network devices into an ethernet switch. You can then tap SETUP -> Wings on FLX, and ensure FLX is also set to receive a DHCP IP address if the wings are also configured that way. Kind regards, Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
