Hi,
I'm sure this is pretty obvious but I don't use Zero 88 desks much. I'm using a Jester 24 that is in a school. I have added a few extra palettes to help me but how to a label them so they say the actual colour rather than "colour 1", etc
Thanks,
Loz
Hi Loz,
When you are in Program Mode on the Jester ML, tap the colour palette you wish to name, press the right arrow key to select the name field, and then press ENTER. The MFKs will then allow you to type in the name, or you can use a USB keyboard.
Hope this helps,
