Hi folks,
This is more a feature request than anything else...
On the IOS remote app for the FLX, is it possible to get a rem dim button on the syntax screen? When using the apple watch remote, there is a remdim option as you scroll through each fixture. It would be great if we could do this on the IOS phone app too...
Thanks for the request. You currently can't access Rem Dim from the ZerOS Remote App.
If you are using the ZerOS Monitor app viewing the Faders desktop, you could assign a UDK to be a Rem Dim function, which you could then use via the app.
Hope this helps,
