AVJB Posted June 23, 2019 Report Share Posted June 23, 2019 (edited) I carefully changed battery on my fat frog (2007 version) and when powered up chan flash buttons for 1-12 permanently on. faders not working and GM only displays to 78%. Also the override pot on 'Go' is flashing ! Looking like fader board has gone down as if I disconnect it rest of desk seems to work. Any advice please and..... I guess obvious question - any one know (if or) where spares are available. UPDATE: I'm pleased to say problem solved checked the DIP switch and one had been changed (found what they should be on the Forum - thanks) Edited June 23, 2019 by AVJB update Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted July 1, 2019 Report Share Posted July 1, 2019 Hello, Glad to hear you solved the issue. Let us know if we can help with anything else. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
kgallen Posted July 1, 2019 Report Share Posted July 1, 2019 Oh, the old "I just changed the battery but magically the DIP switch settings (on the fader PCBs nowhere near the main-board PCB) got changed" issue. DIP switches are hard enough to change when you deliberately want to change them, I've never figured how the DIP switches inside Frog consoles get accidentally changed and I've done the battery inside mine 4 or 5 times... 😏 Anyway, glad you're sorted! Quote Link to comment Share on other sites More sharing options...
iank99 Posted July 1, 2019 Report Share Posted July 1, 2019 Yeah - those pesky DIP switches have a mind of their own... If it hadn't been the DIP switches - I do have a stock of reclaimed fader boards for the Frog series Quote Ian Knight aka The Service Guy - www.serviceguy.co.uk Link to comment Share on other sites More sharing options...
