cucumberbob Posted June 18, 2019 Report Share Posted June 18, 2019 Hi all, I'm trying to have a button on my FLX which will fade to blackout over (for sake of argument) 3 seconds. Is there a way I can do that using a dedicated UDK? Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted June 18, 2019 Report Share Posted June 18, 2019 Hello, For this, type 1 THRU @ ., Tap RECORD, and then tap a UDK. Hold SETUP and tap the UDK to open its Settings. In the Flash function, change this to Latch, and change the mix mode to LTP. You can then configure fade times, and click OK. You should then find you can use this UDK to fade all fixtures to 0 over a fade time. Hope this helps, let me know how you get on. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
