Hello everyone,
I'm wondering if it possible to record only one parameter of a device to a cue.
f.expl. only Dimmer of each device to one fader
I tryed several possible solutions without success.
Thx for your ideas.
Br
The theory is you just record the tagged parameters. For intensity this should be easy as if you just alter the brightness of a fixture that’s the only thing recorded and all other parameters will track.
Make sure in Record Options both Snapshot and SmartTag are off i.e. blue
As Kevin says, only parameters that you change will be recorded, if SmartTag is disabled. To access the Record Options, you can press and hold RECORD. In here ensure SmartTag has a blue stripe, meaning deselected.
From now on, if you simply push up channel faders for your fixtures and tap RECORD, only intensity will be stored.
Hope this helps,
Hi Claude,
If so, your console is in basic programming mode. To change this, press SETUP -> Settings, and ensure Tracking Options are enabled. Then exit SETUP, and press and hold RECORD. The SmartTag option should be available - ensure that the console also has “Cue Only” selected, unless you would like to program cue stacks with tracking behaviour.
Hope this helps,
