Oliver Posted June 15, 2019 Report Share Posted June 15, 2019 (edited) Hi how are you. Ive got two discharge moving lights and i cant get the shutter open to get the light working. Lamp is on just cant controller shutter. Any soultions Edited June 15, 2019 by Oliver Spelling mistake Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted June 15, 2019 Report Share Posted June 15, 2019 Hi Oliver, Does this Fixture have a shutter and intensity parameter? You can check this by consulting your fixture’s manual. The shutter should be defaulted to open, meaning all you’ll need to do is raise the fixture’s intensity. This can be done by pressing FIXTURES, selecting your fixtures, and using the wheel, or pressing HOME. To check the shutter is open, tap BEAMSHAPE, until you find the shutter parameter. Hope this helps, Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Oliver Posted June 16, 2019 Author Report Share Posted June 16, 2019 Hey Edward, Yes it does. I have already raised and opened the shutter still nothing happening. Cheers, Oliver Quote Link to comment Share on other sites More sharing options...
kgallen Posted June 16, 2019 Report Share Posted June 16, 2019 Have you got the fixture in the same mode as the fixture definition you’re using on the desk? What is the make/model of the light? Quote Link to comment Share on other sites More sharing options...
