Posted (edited)
Hi how are you.
Ive got two discharge moving lights and i cant get the shutter open to get the light working. Lamp is on just cant controller shutter. Any soultions
Edited by Oliver
Spelling mistake
Hi Oliver,
Does this Fixture have a shutter and intensity parameter? You can check this by consulting your fixture’s manual. The shutter should be defaulted to open, meaning all you’ll need to do is raise the fixture’s intensity. This can be done by pressing FIXTURES, selecting your fixtures, and using the wheel, or pressing HOME. To check the shutter is open, tap BEAMSHAPE, until you find the shutter parameter.
Hope this helps,
