Hoping this is an easy issue...
On our FLX 7.9.5, the lights on the UDK buttons don't illuminate when pressed. Any idea why? Im using 4 as Rem Dim, and 1 to invert RGB from the default 100 to 0 on latch.
They don't.
You can "test" them by putting a change in the programmer (say 0@@) then when you hit RECORD then any empty playback or UDK buttons should flash (they won't if they are programmed).
Actually, i think ive solved it...
Originally i programmed the console on PhantomOS and loaded the show onto the console. If i delete the UDKs and reprogram on the console they work as expected, highlighted when pressed or on latch.
Not sure if this is a glitch with programming on phantom?
