O Thompson Posted June 14, 2019 Report Posted June 14, 2019 Hoping this is an easy issue... On our FLX 7.9.5, the lights on the UDK buttons don't illuminate when pressed. Any idea why? Im using 4 as Rem Dim, and 1 to invert RGB from the default 100 to 0 on latch. Quote
kgallen Posted June 14, 2019 Report Posted June 14, 2019 They don't. You can "test" them by putting a change in the programmer (say 0@@) then when you hit RECORD then any empty playback or UDK buttons should flash (they won't if they are programmed). Quote
O Thompson Posted June 14, 2019 Author Report Posted June 14, 2019 Actually, i think ive solved it... Originally i programmed the console on PhantomOS and loaded the show onto the console. If i delete the UDKs and reprogram on the console they work as expected, highlighted when pressed or on latch. Not sure if this is a glitch with programming on phantom? Quote
