nbaldwin Posted June 14, 2019 Report Posted June 14, 2019 We received a donor LF96 (partly damaged, no longer used) that I've harvested spare parts from including the main PCB (the one with the CF slot). We have a LF48 that has a damaged VGA socket so was hoping to swap out it's main PCB for the donor LF96 one. 1) I'm assuming that they're the same PCB? 2) Is there anything I should do prior to swapping regarding backing up the LF48? Obviously all of our show data is saved but what about the fixtures? If I just put the CF card from the 48 into the 96 PCB when I swap them, will all of our fixture data be on there and load OK? Thanks, Neil Quote
iank99 Posted June 15, 2019 Report Posted June 15, 2019 They are the same PCB - configuration between the two types is done by a combination of firmware & data on the CF card I believe. I would save a show file if you're able to - just in case (I believe in Miurphy's law!). I'm not sure about swapping the CF Card over but as you're fitting a CF from an LF48 on to a board that was a 96 - you won't lose anything in terms of "identity". A quick phone call to Keith should confirm this (I've never done it so can't be certain) - swap the battery on the "new" mainboard too for good measure. Quote Ian Knight aka The Service Guy - www.serviceguy.co.uk
Edward Z88 Posted June 15, 2019 Report Posted June 15, 2019 Hi Neil, As Ian mentions, I would recommend giving Keith a call, or emailing us at support@zero88.com, for instructions and advice on this. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
