Guest Javi Posted May 3, 2004 Report Posted May 3, 2004 Hello! I'm a boy from Spain that works at the theater of one school. I've got twenty four lamps conected. I've got a Demux 44 and it has four outputs of dmx that goes to the old lighting desk but the problem is that the zero 88 hasn't got four dmx outputs, it has only one what have I got to do help me please!! I've got an act next month help, help! Thanks for all. Javi
sam.henderson Posted May 3, 2004 Report Posted May 3, 2004 Me confunden levemente pues su inglés no es grande. Si usted explica en español entonces puedo intentar y utilizar software y un poco mi conocimiento para traducir. Apesadumbrado si usted no puede entender esto fue hecha usando software de la traducción. Adios SAM Sam for a interactive training suport program on how to use your fat frog effectivly why not look at my frog training program-
Haytech Posted May 4, 2004 Report Posted May 4, 2004 Hi Javi, I doubt that "demux" is a dimmer. Zero88 Demux48 is a demultiplexing unit creating analogue signals for dimmers that don´t have DMX ... try to put a DMX cable with 5 pin XLR connector from your desk´s DMX output to your demux´s DMX input then everything should be under control of the desk. The other four cables are definitely non DMX so beware of putting them to your desk. Lightdesk :mrgreen: DMX cable Demux 48 (demultiplexes 48 chans of DMX to 48 chans +/- 10V DC I wish you success Sebastian Sebastian H. Pro - Sound Showtechnik The secret to creativity is knowing how to hide your sources. Albert Einstein "You can get a lot more done with a kind word and a gun" Al Capone
