RobinG Posted June 4, 2019 Report Posted June 4, 2019 Hey there, So I know on an avolites you can run battens on there highest channel mode and use the shape Gen and run them in super fixtures to get separate cell chases, Is there a way to do it on the Orb XF? Quote
kgallen Posted June 4, 2019 Report Posted June 4, 2019 You need to patch each cell as a separate fixture plus another "fixture" for any common channels. If you have a search on the ZerOS/FLX/Solution forums it's asked quite a lot on there, so there are some comments from the Z88 chaps. Quote
Edward Z88 Posted June 8, 2019 Report Posted June 8, 2019 Hi Robin, Hope Kevin's comment has helped you out. When each pixel is patched as its own fixture, all pixels can be selected, and effects can be offset across them. If you have any questions just let us know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
