Dave Masters Posted June 3, 2019 Report Share Posted June 3, 2019 On a S24 console, is there anyway to access Waveforms, like on the FLX range..? If not, is there a way to create Effects from scratch? Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted June 3, 2019 Report Share Posted June 3, 2019 Hi Dave, No - FLX S consoles only have access to the 45 auto effects. These can then be mixed and edited, which can then be stored as your own effect palettes. There is no way of accessing Waveforms on FLX S to create your own. A work around could be to create the effect Waveforms you would like blind, using Phantom ZerOS running as FLX. You’d then be able to load the show file into your FLX S to access the custom effect - bear in mind there is currently no way of importing just an effect palette into your show. Hope this helps, Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
