PhilN Posted June 2, 2019 Report Share Posted June 2, 2019 Hi can anyone help. I have recently updated my leap frog (with the latest Zeros software update). Following the update i re added my fixtures back in 4x Martin Mac250+ 6x Adj V bar packs 4x Adj Ubh12 batterns i can select colours from the mfks however there used to be some pre loaded effect basic effects like “ square. Triangle “ these are not showing in the mfks anymore . If I press the effects key it show “no effects” if I press Auto create the red light goes out under no effect but the mfk’s remain blank. Can anyone offer any help. This also is a problem for my ADJ lights as the colour effects have also gone. thanks phil Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted June 2, 2019 Report Share Posted June 2, 2019 Hi Phil, Sorry about that - a couple people have found the same issue, which we’re investigating. You can download this file, load it into your console, turn it off, turn it back on, click “Automatically Create Effect Palettes” and you should be back up and running! Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
PhilN Posted June 2, 2019 Author Report Share Posted June 2, 2019 2 hours ago, Jon Hole said: Hi Phil, Sorry about that - a couple people have found the same issue, which we’re investigating. You can download this file, load it into your console, turn it off, turn it back on, click “Automatically Create Effect Palettes” and you should be back up and running! Thank Jon just downloaded and updated problem resolved some good effects on the update. Thanks for your help. phil Quote Link to comment Share on other sites More sharing options...
