kgallen Posted June 1, 2019 Report Share Posted June 1, 2019 I need to create an effect on RGBW LEDs to depict (gentle) movement of the sea. In this instance I'll have 4 mover wash LEDs and 3 non-mover LEDs as backlights. ZerOS 7.9.5. I think this would be a colour effect (and maybe but not necessarily a position effect for the movers - gentle side to side swoosh?) that uses probably an offset sine function to colour fade some mid-blues, paler-blues and whites. Can I pick your brains (Edward) on how this could be set up (then saved as an effect palette I presume)? If it's good, maybe this could be added to the Auto Effects palette for 7.9.6 as "Water" to go with the new "Fire" 😊 Thanks as ever! Kevin ps My movers don't have any usable gobo functions for this - they are Showtec Shark Wash and Shark Combi-Spot (you made me the fixture definition). Quote Link to comment Share on other sites More sharing options...
van den abbeele Eric Posted June 1, 2019 Report Share Posted June 1, 2019 hello Kevin, you use ZerOS 7.9.5 ? You've no problem ? I m too afraid to do the update and have too much problems after. I Have big performance every week... And can take the risk to haven't a FLX ready to work... What do you do in your Job ? Working in a theater ? Other ? Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 4 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 4 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 10 LS200 - Spot 200w // 19 Wash Par 12 X 18W // 12 BOWLDER 12X40w WASH // 12 PARZOOM 19 X 15w // 7 LY 400 - BSW CMY LED 400w Link to comment Share on other sites More sharing options...
Jon Hole Posted June 1, 2019 Report Share Posted June 1, 2019 It looks like the Shark Combi-Spot has some gobos that could help provide some texture? Overlap the beams and ensure they're out of focus. You could then play with adding in some "animation" but I'm not sure Pan and Tilt are the correct option. Maybe try adding a sine wave to the focus parameter just to bring the gobo in an out of focus (although never a hard focus). Potentially a slight intensity effect too. With the LEDs, you could try putting a small sine effect on the Green and Blue channels just to slowly pulse them slightly, and offset that across the fixtures - probably randomly, but maybe see if offsetting them in order helps suggest movement. Give the Green and Blue parameters slightly different speed and sizes from each other so you don't always get exactly the same shades. Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
kgallen Posted June 2, 2019 Author Report Share Posted June 2, 2019 Thanks Jon. I think I have the basis of a usable "sea" now. Same snag recording it as ICBE as this thread though. Quote Link to comment Share on other sites More sharing options...
