van den abbeele Eric Posted May 31, 2019 Report Posted May 31, 2019 Hello Just need a clarification. Until now I had an Ethernet cable crossed between the MACBOOKPRO and the FLX. But I want to be able to use an Ethernet switch. Because I want to take a Wifi kiosk in a few week, wich to control the FLX with Iphone or Ipad. So to go from the FLX to the Switch and the switch to the computer, I take straight or crossed cables? thank you so much Eric Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 4 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 4 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 10 LS200 - Spot 200w // 19 Wash Par 12 X 18W // 12 BOWLDER 12X40w WASH // 12 PARZOOM 19 X 15w // 7 LY 400 - BSW CMY LED 400w
Jon Hole Posted May 31, 2019 Report Posted May 31, 2019 Hi Eric, You need crossover cables to do this. Jon Quote Jon Hole Global Product Manager, Systems and Control
martin-144 Posted May 31, 2019 Report Posted May 31, 2019 Hi Eric and Jon, does not every Ethernet switch nowadays have a auto-negotiation function and can detect if there is a cross or not cross cable connected? I work a lot in this topic and I think it does. So in my opinion it shouldn't matter which cable you use. Please correct me if I am wrong. Martin Quote
Jon Hole Posted May 31, 2019 Report Posted May 31, 2019 Hi Martin, I almost went down this route in my reply, but thought that it was adding unnecessary complexity. It’s certainly true that a lot of devices do - the MacBook Pro certainly, and probably the switch. However, I couldn’t guarantee this, and “correct procedure” would be to use a crossover cable in this situation. Quote Jon Hole Global Product Manager, Systems and Control
van den abbeele Eric Posted May 31, 2019 Author Report Posted May 31, 2019 Thank you both for this answer ... 1 / Second question, on the side of the switch is it necessary to take one that can be parameterized? Or a standalone switch will work without worries? 2 / This brings another question on a wifi terminal. IF so I have a cross cable between FLX and the Switch Cross cable between Switch and MAc. I imagine that for the Wifi terminal, it will be the same. Cross cable of the switch to the WIFI terminal? thank Eric Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 4 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 4 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 10 LS200 - Spot 200w // 19 Wash Par 12 X 18W // 12 BOWLDER 12X40w WASH // 12 PARZOOM 19 X 15w // 7 LY 400 - BSW CMY LED 400w
