van den abbeele Eric
Switch between FLX / Mac OS (Capture) / Wifi hotspot
Hello
Just need a clarification.
Until now I had an Ethernet cable crossed between the MACBOOKPRO and the FLX.
But I want to be able to use an Ethernet switch. Because I want to take a Wifi kiosk in a few week, wich to control the FLX with Iphone or Ipad.
So to go from the FLX to the Switch and the switch to the computer, I take straight or crossed cables?
thank you so much
Eric
Hi Eric and Jon,
does not every Ethernet switch nowadays have a auto-negotiation function and can detect if there is a cross or not cross cable connected?
I work a lot in this topic and I think it does. So in my opinion it shouldn't matter which cable you use. Please correct me if I am wrong.
Martin
Hi Martin,
I almost went down this route in my reply, but thought that it was adding unnecessary complexity.
It’s certainly true that a lot of devices do - the MacBook Pro certainly, and probably the switch. However, I couldn’t guarantee this, and “correct procedure” would be to use a crossover cable in this situation.
Thank you both for this answer ...
1 / Second question, on the side of the switch is it necessary to take one that can be parameterized? Or a standalone switch will work without worries?
2 / This brings another question on a wifi terminal.
IF so I have a cross cable between FLX and the Switch
Cross cable between Switch and MAc.
I imagine that for the Wifi terminal, it will be the same.
Cross cable of the switch to the WIFI terminal?
thank
Eric
