Hi Thierry,
For this you need to use the syntax pad on the console. If you don’t have a keyboard attached, after typing LOAD and pressing the first number key on the MFKs, tap SPECIAL, and on MFK page 2 you’ll be able to continue typing the cue number.
You can then tap the playback’s button to load the cue number from that playback.
Hope this helps,
Email Support
Hi Edward,
i know what  the "Load button" does, but i was talking about that:
I didn't know that i had to type "Special" again to reach the second digit page, I did try everything but not that
