This configuration is done in the Playback Settings. To open the Playback Settings window, press and hold SETUP and tap the Playback button. If the Go button seems to have stopped working, make sure the button is configured to Go Fade. To stop the playback resetting back to cue 1 when the fader is lowered, tap Raise & Lower ->, and disable Release on Lower.
Hope this helps,
