Hello everybody,
how to edit a particular intensity of a particular projector in a cue ? i can increase without any problems and update the cue when it's about automatics and with traditionals pebbles or profiles, but i can't decrease an intensity  with traditionals (something to do with htp/ltp ?)
how to delete "live" a standard fixture in a cue  ? i can manage my cues when it's about automatics fixtures, but with a profile or a pebble convex ?
OK, my channel MixMode is HTP, i think i must set it to LTP, and only keep HTP for my submasters.
Now, i can make a device disapear by decreasing it's intensity, then updating the cue...
Hi Thierry,
That’s correct, when the channel fader’s mix mode is set to HTP, it will mix with the cue values, whereas LTP allows you to take priority over cue values.
Alternatively to edit a cue, you can use the syntax LOAD x ENTER, which will load cue x of the current playback into the programmer.
Hope this helps,
