Effect and FLX ?
van den abbeele Eric
I have questions about the aspect of the effects.
1 / For some light consoles (Chamsys, GrandMa, etc.), the aspect of the effects is a great strength.
We can quickly do something that can be thrilling for an audience ...
The effects can as much play on
- the movement of a projector
- Color change
- gobo change
- play on the opening of the Zoom,
- opening prism closure,
etc ..
- and several actions grouped with some ease ...
For the FLX, this part will be able to evolve to increase during a show the capabilities of animations?
2 / if I program imagine in the "playback 1", a sequence of various motions in chase version (40 cues for example), can I recall this playback in a master cue playback and if so how to proceed?
Thank you for your patience to answer us and see you soon,
Eric
Hi Eric,
The 32 effects on FLX currently adjust Intensity, Position, Colour, and Beam. In ZerOS 7.9.5, this will be increased to 45 auto-effects, including improvements on the existing, and many new effects.
To do this, you will need to trigger playback 1 from a cue in the Master Playback. To do this go into the Cue Settings in the cue in the master playback you wish playback 1 to be triggered by. Then press Macros..., and next to Trigger Cue Stacks click Add. Any programmed playback buttons on the console will then flash, which allows you to tap playback 1 to trigger it. Click OK on the macros window, and then the Cue Settings. When you go into this cue, as well as the cue running playback 1 will be triggered too.
Hope this helps,
Product Specialist
Email Support
