Uriahdemon Posted May 7, 2019 Report Posted May 7, 2019 Hi all, hope you are well. I was at a venue where they had an Orb in play and they had a monitor screen up where there were multiple pages of cues up. There were approximately 48. I was wondering how you do this and is it possible to bring up multiple cue pages up at once on the FLX. At this time I am having to select through the 10 pages to see what is running and what is not. Grateful for your input as usual. Rgds Mac Quote
Edward Z88 Posted May 8, 2019 Report Posted May 8, 2019 Hi Mac, I'm very well thank you hope you are too. This isn't currently possible on FLX. Only one cue stack can be viewed at a time, by holding VIEW and tapping the playback you wish to look at. It is also worth mentioning that when viewing the Faders window, the on-screen faders show the current (C) and Next (N) cues, so this may also help to see what is running. Another way of seeing what playbacks are controlling which fixtures, is to press "Source" at the top of the Output Window. This will give you an annotation of which cue is in current control of that fixture. The way multiple cue windows can be opened on ORB consoles is by using the syntax VIEW STACK x ENTER. All the best, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Uriahdemon Posted May 8, 2019 Author Report Posted May 8, 2019 Thanks very much Ed. I will give the tips you mention above a try !! Quote
