Yves Posted April 27, 2004 Report Share Posted April 27, 2004 when I turn on my desk (mambo frog / software 9.0) and want to play the progs that are there from a previous show, it takes about 1sec for the subs to reach 100%. when I then make a new program it works fine but the progs that are still in there still have the same problem. Quote Link to comment Share on other sites More sharing options...
Paul Posted April 28, 2004 Report Share Posted April 28, 2004 What version of software was the show originally created with? Release 9.0 added the 'fade times on submasters' function. It might be that if you load a show created on a previous version of software, which didn't have this feature, that the submaster fade times pick up some odd values. Check the submaster fade times, and set them to zero if you want the fader to respond instantly. Quote Link to comment Share on other sites More sharing options...
Yves Posted April 28, 2004 Author Report Share Posted April 28, 2004 I think the show was created in the same version as I wanted to play it in Quote Link to comment Share on other sites More sharing options...
Jazzy Posted June 14, 2004 Report Share Posted June 14, 2004 Hi all, Had a bit of a strange one yesterday when I booted up the desk, all the submasters (which I had transferred the memories to with "Transfer with no time") had all suddenly got the default 3 second fade up/down times and even the ones I transfered with times had also reverted to the default times. I have been running this particular show over the last 3 - 4 weeks, all programmed on OS 9.6 and no problems till now. I reloaded the memories to subs with the relevent times and no times and it worked fine ( although I lost all my submaster names. Is that normal?) I'll boot up the desk a bit later to see if it has done it again, (didnt get to bed till 6.00am this morning.) Has any one else experienced this? Any Ideas? Quote Link to comment Share on other sites More sharing options...
K-Nine Posted June 14, 2004 Report Share Posted June 14, 2004 I will set up a fat frog here and transfer a set of memories with time onto a page of submasters, and without time onto another page. I will power down the desk and then power it up after a period of time, and see if the problem can be reproduced. As to the overwriting of the names - did you name the submasters independently after transferring the memories ? If you re-transfer the memories onto the subs then the names will be overwritten as you are effectively overwriting the whole submaster. If you name the memories before transferring them, the name should also be transferred to the submaster. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
Jazzy Posted June 14, 2004 Report Share Posted June 14, 2004 Pretty much except that the subs were running the full 3 second up down times and all the Fade Up / Fade Down fields on the LCD and monitor had changed from 00.00.0----00.00.0 To 00.03.0-------00.03.0 for the subs that had been transferred with "Transfer with No Time" and any subs that had modified times ie, UP 00.10.0- Down 00.04 reverted to 00.03.0. As I said I have run this show about ten times over the the last 3/4 weeks with no problems. It is the original show, that is I havent reloaded it from disk and the desk has not been used for anything else. The only mods are position palettes for different venues. Quote Link to comment Share on other sites More sharing options...
Jazzy Posted June 14, 2004 Report Share Posted June 14, 2004 No I only Named the Subs not the individual memories, so that explains that. I had a feeling that might be the case. Quote Link to comment Share on other sites More sharing options...
GLX Posted June 14, 2004 Report Share Posted June 14, 2004 Jeff is that you? Quote Link to comment Share on other sites More sharing options...
Jazzy Posted June 15, 2004 Report Share Posted June 15, 2004 Hi all, I fired up the desk yesterday afternoon cycling it on and off about 10 times and everything stayed fine. A one off glitch perhaps? Good job I checked it a couple of hours before the show. Yes 'tis I Gary! Quote Link to comment Share on other sites More sharing options...
K-Nine Posted June 15, 2004 Report Share Posted June 15, 2004 I will set up a fat frog here and transfer a set of memories with time onto a page of submasters, and without time onto another page. I will power down the desk and then power it up after a period of time, and see if the problem can be reproduced. I powered up the desk this morning - the page of submasters which had memories transferred without time now have times which appear to be the times of the memories (not the submaster default times). I have tried another couple of tests this morning and it would appear that the problem lies when reloading the show from flash, and does not always appear simply by power cycling the desk. I have passed this information on to our software guy for further investigation. Frog Reference No 5489 - Times appear on submasters after restarting the desk - Bug to be investigated and fixed Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
Jazzy Posted June 15, 2004 Report Share Posted June 15, 2004 Strange one, I'll keep an eye out for it until there is a patch for it. Cheers. Quote Link to comment Share on other sites More sharing options...
Jan Giezen Posted June 15, 2004 Report Share Posted June 15, 2004 I 've had the same problem a few weeks ago twice. After that I had no problems again until last week. Again all submasters had the default fade up/down time and I had to reload all tje memories to the submasters. I was just to post this problem by myself, but it seems that some of you guys where ahead of me. I'm not sure, but I think the problem occurs when you reboot the desk after it has saved the memory to flash. 8O Quote Link to comment Share on other sites More sharing options...
K-Nine Posted June 16, 2004 Report Share Posted June 16, 2004 .. Again all submasters had the default fade up/down time .. Are you sure the times were the default SUBMASTER fade times or are they the fade times of the transferred memories, which if they haven't been modified would also be 3 seconds ? During testing yesterday I deliberately changed the submaster defaults and modified the times of the memories prior to transferring them. When the desk was powered back up, it was definitely the memory fade times that were appearing on the submasters, which previously had zero times. ... I'm not sure, but I think the problem occurs when you reboot the desk after it has saved the memory to flash. 8O This is the conclusion I came to as well. If you transfer memories without time, and simply power cycle the desk, the corect times come up. However, if you modify something in the Desk Setup and save it, this I believe causes the show to be saved to flash memory. Then if you power cycle the desk, the times on the subs appear to change. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
Jazzy Posted June 16, 2004 Report Share Posted June 16, 2004 Hi, About the default times appearing being memory times as opposed to sub times you are most likely right. As for changing the desk setup I presume you mean entering Superuser altering something and then saving changes when exiting Superuser. The thing is I loaded OS 9.6 ( which I had trouble with, see earlier posting " OS wont upgrade") entered superuser setup all the desk defalts and stuff, assigned the fixtures, saved changes and exited superuser. The desk went out on this current show the very next day, I programmed it and opped it myself and as I said the only mods since are to the position palettes to suit different venues.I have made no changes to the desk setup since. Dose altering the Position palettes cause the desk to save the show to flash memory? But the fact that I have altered them about ten times but only experienced this problem once is odd. Is it possibly something else or dose the desk automaticaly save to flash after a certain amount of power cycles? Quote Link to comment Share on other sites More sharing options...
K-Nine Posted June 16, 2004 Report Share Posted June 16, 2004 I have consulted with our software guru and his response was as follows: When programming or editing memories, submasters, palettes etc. the changes are saved to the nvr (non volatile RAM), then when that gets full, the full show is written to the flash memory, and the nvr is cleared. On power-up, the desk loads the show from flash and then applies the changes stored in the nvr. So it would appear if the changes to the submaster data are retrieved from the NVR, then the times are OK, but if the data is retrieved from the flash, the default times appear. Changing and saving the Desk Setup forces the desk to save the show to flash and clear the NVR. If you don't change the desk setup, the desk will only save the data to flash when the NVR gets full. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
Jan Giezen Posted July 18, 2004 Report Share Posted July 18, 2004 Been off for some time .... Is there already a follow-up for this problem, or will there be one ? Quote Link to comment Share on other sites More sharing options...
Yves Posted July 19, 2004 Author Report Share Posted July 19, 2004 don't know, but had the same problem again this weekend. Quote Link to comment Share on other sites More sharing options...
daoops Posted July 24, 2004 Report Share Posted July 24, 2004 I got this problem to, but it occured firt when I booted a saved show from floppy causing me big problems since the show I was running was 30min from starting. All the subs got 3min fade times. Is there a solution in progress for this ? Quote Link to comment Share on other sites More sharing options...
K-Nine Posted July 26, 2004 Report Share Posted July 26, 2004 Loading the show from floppy disk will probably display the same problem as it is very similar to loading the show from flash - see earlier posts. This problem will be investigated. I hope you meant 3 seconds for the fade times, not 3 minutes as that would really be annoying 8O Note - This problem only appears to affect the submasters with transferred memories. The times on submasters which have been recorded directly with channel/fixture data appear to reload correctly. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
Jan Giezen Posted October 16, 2004 Report Share Posted October 16, 2004 Is there already any sight on when this one may be solved? My LJ becomes very nervous when it is not possible to correct the position pallettes when the musicians arrive just before the show starts whithout the canche he again :evil: has to transfer all the memories to the submasters :? Quote Link to comment Share on other sites More sharing options...
LP Posted April 18, 2006 Report Share Posted April 18, 2006 Hello Froggers When I programmed some chases and tranferred them to submasters no time and i want to load it again on a different location all the memories on the submasters are working with time I don't know what I do wrong If someone can help me please Thanks in advance Quote Link to comment Share on other sites More sharing options...
