Flx s48 auto problem
jimbo-nomads
I have a cue with general stage lighting plus a set of led bars simulating early morning. The next cue is a cross fade to bright morning on the led bars over 5 minutes. Done manually on the go button the stage stays up and the led bars crossfade colours. Done automatically the whole stage goes dark and comes back over the 5 minutes with the colour fade.
Any ideas?
Hi Jimbo,
I have loaded your show file into Phantom ZerOS and have taken a look. I can't seem to recreate the issue you are seeing.
I have gone into cue 5 from cue 4, and also cue 13.5 from cue 13, and the 5 min cross fade runs correctly. Adding in Auto After or Auto With triggers on cues 4 or 13.5 also results in a smooth crossfade running from the previous cue, without the whole stage going dark.
Could you confirm it is these cues?
