I have a cue with general stage lighting plus a set of led bars simulating early morning. The next cue is a cross fade to bright morning on the led bars over 5 minutes. Done manually on the go button the stage stays up and the led bars crossfade colours. Done automatically the whole stage goes dark and comes back over the 5 minutes with the colour fade.
Any ideas?
Interesting, can’t think of any reason this may be happening. Please could you attach your show file the problem is present in, and list the cues that are causing the issue?
All the best,
Email Support
Hi Jimbo,
I have loaded your show file into Phantom ZerOS and have taken a look. I can't seem to recreate the issue you are seeing.
I have gone into cue 5 from cue 4, and also cue 13.5 from cue 13, and the 5 min cross fade runs correctly. Adding in Auto After or Auto With triggers on cues 4 or 13.5 also results in a smooth crossfade running from the previous cue, without the whole stage going dark.
Could you confirm it is these cues?
Email Support
Cue 4 to 5 happen 10 pages apart. The problem shows itself from 13 to 13.5. Tonight is the last performance so won't be able to check it out for some time now. Thanks for looking at it and I'll get back to you at some point.
