Elof Posted April 8, 2019 Report Posted April 8, 2019 Hi! As the title says. How do I update my FLX s24. Cant find a single tutorial or instruction. Best regards! Quote
Edward Z88 Posted April 8, 2019 Report Posted April 8, 2019 Hello, Software update instructions can be found in the release notes included with the software download... Simply download the software, and extract the software file to the root of a USB stick. Plug the USB stick into the console, tap SETUP -> Load File, and choose the software file application. The console will then perform the installation. Software updates will remove the current show file from the console, so make sure you’ve saved a copy to USB if you would like to load it back into the console afterwards. Hope this helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
dramatechws Posted April 17, 2023 Report Posted April 17, 2023 Put it on a USB, put it in the desktop, setup, load, nothing. Not seeing any file on the drive. Quote
kgallen Posted April 17, 2023 Report Posted April 17, 2023 FAT32? 8GB stick or less? USB2.0 (not USB3.0)? Not a Kingston Traveller? In the root directory? The right file? i.e. not the Phantom ZerOS exe? Quote
DALX Posted April 17, 2023 Report Posted April 17, 2023 There is no mention of USB Thumbdrive limitations in the software release notes. There is a mention in this recent FLX forum post https://www.zero88.com/forum/topic/7320-usb-memory-sticks-compatible-with-flx/ Quote
Edward Z88 Posted April 17, 2023 Report Posted April 17, 2023 3 hours ago, dramatechws said: Put it on a USB, put it in the desktop, setup, load, nothing. Not seeing any file on the drive. Software update instructions can be found here... https://www.zero88.com/manuals/zeros/setup/load/zeros-software Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
dramatechws Posted May 20, 2023 Report Posted May 20, 2023 Yeah, must've been the drive, tried another and it worked. 1 Quote
