Software update instructions can be found in the release notes included with the software download...
Simply download the software, and extract the software file to the root of a USB stick. Plug the USB stick into the console, tap SETUP -> Load File, and choose the software file application. The console will then perform the installation. Software updates will remove the current show file from the console, so make sure you’ve saved a copy to USB if you would like to load it back into the console afterwards.
Hope this helps,
  • 4 years later...
  • 1 month later...
