ArdenJonno Posted April 1, 2019 Report Share Posted April 1, 2019 Hi there, Is it possible to save to the fader playbacks using only the riggers remote on Windows? I can save to the main playback by using "record [1] Enter" but I can't seem to find the correct thing to type into the command syntax to achieve this. Using a Zero88FLX Thanks for your help Jonno Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted April 1, 2019 Report Share Posted April 1, 2019 Hi Jonno, How are you recording cues using ZerOS Remote Monitor for Windows? There is no hot key mapped for RECORD? When RECORD has been pressed on the console, you can however choose a playback to store onto using the Faders window. If the faders window isn't open on the ZerOS Remote Monitor, ensure that the console has External Monitor Enabled (tap SETUP -> System Settings -> External Monitor -> Enabled), and tap VIEW. When this is displayed you can tap RECORD, and tap a virtual playback to store onto. You can also type a defined cue number, before choosing the playback to store onto. Hope this helps, Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
