jclark2906 Posted April 26, 2004 Report Posted April 26, 2004 I've programmed a touring show using a Mambo Frog and 8x Mac 250+. The show isn't supposed to tour with any technical staff (although I am for now!), the idea being that every memory references one of a small number of Position Pallettes, and so the only thing to change for each new venue is the position Pallettes. The problem is this. I modify and save the Position Pallettes according to the venue, save the show to disk, the show runs perfect. Next venue, none of the memories now reference Position Pallettes, all show real position data and/or have movement effects, so have to repeat the whole process again! Am I missing somehting obvious here? Quote
jclark2906 Posted April 26, 2004 Author Report Posted April 26, 2004 Just read the Problems with Effects Generator thread in Bugs, sounds just like what is happening with me, I'll try 9.6 I guess. Quote
Haytech Posted April 27, 2004 Report Posted April 27, 2004 Hi JClark, Surely you know that program a pallette to a cue memory it is required that fixtures are tagged, pallette information is shown on the right wheel group disp. exp. P1 P1 P1 on the position parameters ... then it will be saved on the cue ... as a scene. Quote Sebastian H. Pro - Sound Showtechnik The secret to creativity is knowing how to hide your sources. Albert Einstein "You can get a lot more done with a kind word and a gun" Al Capone
jclark2906 Posted April 27, 2004 Author Report Posted April 27, 2004 yes, I do know that, when the show runs correctly, the Pallette numbers are displayed as expected, it's after the desk is turned off and on again that the problem arises. Quote
K-Nine Posted April 27, 2004 Report Posted April 27, 2004 A problem was identified with cues referencing position palettes when the show was reloaded off floppy disk, or the desk was power cycled causing the show to be reloaded from flash memory. The position data was incorrectly read back, resulting in rogue movement effects being added to the position palettes :oops: This bug has been fixed in Version 9.6 of the software. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
