BoP Posted March 21, 2019 Report Posted March 21, 2019 Hello. I have a Jester ML24 console and I set the LCD display Brightness to zero and now I can not get it back to 50 (I have no monitor). What to do? Can I reset the console (hard reset)? Kind regards Bo Quote
kgallen Posted March 21, 2019 Report Posted March 21, 2019 The manual, p34, says "If the LCD Backlight or Contrast have been set to unreadable values, you will need to connect a monitor to be able to navigate to this menu and set readable values.". It seems your only other option is to know the menu structure and be able to navigate to the required menu item blind. I don't have a Jester - Edward might be able to supply the "footsteps" you need to navigate blind from a cold desk start... https://eaton.nanorep.co/storage/nr1/kb/2AD62C9/3879A76B/3A205D35/22/Jester Manual 3.4.pdf Quote
Edward Z88 Posted March 21, 2019 Report Posted March 21, 2019 Hello, To reset the console, these are the keys you'll need to press: Enter Setup, by holding SHIFT and holding MODE, then Arrow down 10 times, and press ENTER. Then Arrow right, and press Enter, which will reset the console. Then hold MODE to leave Setup. To change the Main LCD contrast, again enter Setup, then arrow up 5 times, and press ENTER. Then press ENTER, and hold the up arrow to raise the Back light, and press ENTER. Then arrow down, and press ENTER, and then hold the up arrow to raise the contrast. You should then be able to see your way out of the menus. You may find that using Phantom Jester on PC helps you find your way around the menu structure. Phantom Jester allows you to emulate Jester ML24 on your PC. You can download Phantom Jester for PC here... http://support.zero88.com/975199911 Hope this helps, if you have any queries let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
kgallen Posted March 21, 2019 Report Posted March 21, 2019 ...it's like the dance the UK PM did on entrance to her Party Conference. Don't forget the hip wiggle... (bleughhh). Quote
