Hi there
i'm looking for an "NonDim" Fixture. Same as the Relay Fixture but controlled by the intensity Wheel.
Can't find anything.
Tryed to do it by the Fixture Type Editor. Without succsess.
Help needed.
Regards
Wolfgang
Hi Wolfgang,
You won’t be able to create a fixture where the intensity switches. This functionality is available with a Relay using the Beamshape attribute.
If you wish to use a fader to switch for whatever reason, patch a relay, turn it on, and record to a playback. Then go into the playback settings, choose Raise and Lower, and then set the trigger level to the percentage you’d like the fader to trigger the relay.
Hope this helps, any queries let me know.
