NigelP Posted February 16, 2019 Report Share Posted February 16, 2019 Just a quick question from a newby on the FLX S24. I need to be able to raise the UV channel separately from all the others. There is a very good Knowledge base article about colour mixing RGB but I need to know if the same process works for all 6 channels. I presume it does, but I'm not able to try it until we get into rehearsals and dress so time is very limited if I have to do something else.. Thanks to anyone who can allay my fears! Nigel Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted February 17, 2019 Report Share Posted February 17, 2019 Hi Nigel, Yes, to Record just the UV parameter onto a playback, it is exactly the same process as RGB, as noted in the article here... http://support.zero88.com/1014413041 All you’ll need to do, is ensure the Intensity and UV parameters are at full, and are the only parameters tagged (indicated by having a lighter blue encoder background, and a red intensity value in the output window). You’ll then be able to record this to a playback, ensuring SmartTag is disabled. Dont forget you can download PhantomZerOS onto a PC, so that you can practice this beforehand by emulating a FLX S. PhantomZerOS is available to download here... https://zero88.com/forum/files/file/17-zeros-794/ If you have any queries just let us know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
NigelP Posted February 25, 2019 Author Report Share Posted February 25, 2019 Thanks Edward, that worked. I'm not such a dummy as I thought I was! Really helpful and the effect worked a treat. Nigel Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted February 26, 2019 Report Share Posted February 26, 2019 Hi Nigel, Great, glad to hear it. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
