Effect, be gone!
Howartp
Hi.
I'm with @robhurt on a show. Dress is this Friday, to open on Saturday.
Cue 46 in the attached file is blackout before the interval, then cue 47 is the interval lights.
Channels 9+10 (Infinity iW1915) have an effect on them in cues 45.*
We cannot persuade the FLX to stop that effect when we go to 46. It is moving on dark ("Source: D") but the effect is still active so the fixtures are still dancing.  However the next time they are used is cue 49, static position with intensity.
Opening them in OrbFX Phantom I can't see the effect showing anywhere, though I don't pretend to know FLX or Orb in any great depth.
The same is true about 4-5 other times in the show, where we can't stop the effect, but 46 is the easiest to work out what's happening.
We expected that 9+10 > Effect > No Effect > Update > Enter would sort it.... but the effect starts again as soon as you hit enter.
Any suggestions?
Peter
Old Mother Hubbard 2019.isf
Hi Peter,
I won’t get a chance to look at the show file this evening, however it sounds like you are trying to Update cue 46 with SmartTag enabled. As the fixtures are off in cue 46, any commands you try to update them with, including removing effects, will be ignored if SmartTag is enabled and the fixture is off.
Therefore...
...then press and hold UPDATE, and choose SmartTag from the Update Options so that it is disabled, and then hit ENTER to complete the command (make sure this is a tracking update). You should then find the update is pulled into the cue.
You can turn SmartTag back on again by pressing and holding RECORD/UPDATE, then tap SmartTag so it has a red stripe on it, and then hit RECORD to close the window.
Hope this helps,
Product Specialist
Email Support
Hi Peter,
1 hour ago, Howartp said:
Problem solved!
Great glad to hear it.
If SmartTag does cause you problems, don’t forget you can just disable it and program without it.
The key thing to remember when disabling SmartTag is the console will only store programmer information into cues, not information coming from other cues.
Any queries let me know.
Product Specialist
Email Support
