gmanno Posted February 8, 2019 Report Posted February 8, 2019 Hello I was wondering if there is a way to create a simple flashing (strobe) effect to be added on the pre-existing ones, this is an issue with general fixtures rgb that we currently use, Also is there a sort command to grab all the used fixture in a specific cue? I amen not all available just the one used in that particular moment? Many thanks 😀
Edward Z88 Posted February 8, 2019 Report Posted February 8, 2019 Hello, 1 hour ago, gmanno said: I was wondering if there is a way to create a simple flashing (strobe) effect to be added on the pre-existing ones, this is an issue with general fixtures rgb that we currently use, The existing chaser effect should give you the strobe effect you’re after, if you increase the speed. More Auto Effect palettes such as Lightning Strobe will be coming in the next software update. 1 hour ago, gmanno said: Also is there a sort command to grab all the used fixture in a specific cue? I amen not all available just the one used in that particular moment? If that cue is the only active cue on stage, double tap ENTER, and this will select all fixtures currently on stage, allowing you to adjust them. If you enter Blind mode by holding SHIFT and tap Z, you can hold the playback go button of your cue list, type your cue number, and then release the go button. This will load the cue into the blind programmer, for you to edit. You can then tap UPDATE to store the edits and exit Blind mode. Hope this helps Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
