On FLX, how do I re-arm a playback that I have cleared if that playback is set to 2-way manual? Besides rebooting the console, that's the only method I've found to work, but that's not always a viable option.
thx in advance, Ruud
Hi Ruud,
Currently, to retrigger a Manual 2-way Playback that has been manually released, you have to copy it to an empty playback, and you can then copy it back to the original fader. You will then be able to trigger and operate the playback as normal.
This is a known issue we are working on.
Any queries let me know.
Hi Ed,
Thanks for the swift reply.
Just one more: GoTo [Cue nr] (holding "flash" and typing the nr on the numpad) also doesn't work in 2-way mode, correct? And I also had a lot of trouble adjusting and/or adding cues. (I'm a GO-button man myself but a visiting tech insisted on using the fader to switch scenes, and it really gave me a major headache)
regards, Ruud
Hi Ruud,
Yes that's correct. When the playback fader is configured to Manual Fade, the fader movement is the only method of going into a cue.
You can however choose which cue you would like to be next by highlighting it in the cue list window. When you next move the fader you will then go into this cue rather than the next subsequent cue.
Hope this helps,
