MatthewD
Keyboard Shortcuts for FLX S (using a USB Keyboard or ZerOS Monitor)
Hello, is there a list of keyboard shortcuts for the FLX S consoles for when I'm using a USB keyboard in the console, or for ZerOS Monitor App on a remote PC or iPad?
I have worked out a few., eg selecting / adding / excluding channels.
Are there commands for
  1. Select "1 THRU 10"
  2. Selecting attributes
  3. Thru
  4. Record
  5. Update
  6. Delete
  7. etc.
There is a list on page 5 on the FLX Training Guide ( https://eaton.nanorep.co/storage/nr1/kb/2AD62C9/3879A76B/3AF13603/5/Zero 88 Training Session - FLX training notes.pdf ), but what about for the FLX S models?
 NB:- the "@" symbol on Australian keyboards is on the number 2, whereas in the FLX is expects it to be on 8.  So SHIFT+"8" gives me the "@".
Thanks in advance.
Matthew
Hi Matthew,
A list of keyboard shortcuts compatible with a keyboard/ZerOS Remote Monitor connected to FLX S can be found here...
http://support.zero88.com/998481801
We are looking to extend this list in future.
The syntax page in the FLX training notes is also applicable for FLX S, with the exception of a few buttons FLX S doesn't have. This syntax guide is available here...
http://support.zero88.com/1011387501
(I have removed your duplicate post in "ZerOS Apps" so we can keep all information for the subject in one place)
Hope this helps,
Thanks Edward,
Is there a command for clearing the whole command line?
Pressing Backspace clears one field, but I'm finding I need to press this many times if there's a large command line built up.
Thanks in advance.
Matthew
Hi Matthew,
No, there currently isn't a keyboard shortcut for CLEAR. Backspace allows you to step back through the command line to the previous comma.
All the best,
Hi Edward,
Could this please be put in as a feature request?
Perhaps a "Shift + Backspace" clears the whole command line.
Thanks in advance.
Matthew
Hi Matthew,
Thanks for your comment.
I will make a note of this. An extended list of keyboard shortcuts is definitely something we are looking to implement.
All the best,
