dougalzeb Posted April 22, 2004 Report Posted April 22, 2004 Is there any quick keypress which will allow me to go back a step in the cue stack (for those scary, trigger happy moments!)?Cheers Quote
Haytech Posted April 23, 2004 Report Posted April 23, 2004 Hi dougalzeb there isn´t something like GO+ GO- on the desk the only thing you can do is to press the - button twice before pressing go. cheers Quote Sebastian H. Pro - Sound Showtechnik The secret to creativity is knowing how to hide your sources. Albert Einstein "You can get a lot more done with a kind word and a gun" Al Capone
K-Nine Posted April 23, 2004 Report Posted April 23, 2004 As Haytech says, press the '-' key twice and ten GO, or if you have an external keyboard attached, enter the memory number directly, Enter and then press the GO button. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
dougalzeb Posted April 23, 2004 Author Report Posted April 23, 2004 Boy do I feel stoopid! :oops: That is so simple it hurts! Thanks guys :wink: Quote
LeeStoddart Posted April 26, 2004 Report Posted April 26, 2004 As Haytech says, press the '-' key twice and ten GO, or if you have an external keyboard attached, enter the memory number directly, Enter and then press the GO button. Only problem with this (as I found last night) is that if there is a gap in the programmed Memory numbers then two minus keys don't take you back far enough. I know you can enter the number on the keyboard and you can see on the monitor which memories are actually programmed but in the heat of the moment the instinctive response or "minus minus go" failed me :cry: Quote Lee Stoddart
